Compact Linear-Motor Gantry from Aerotech
June 29, 2010 by admin
Filed under Featured, Linear Guides, Linear Stages / Gantries
Aerotech’s AGS1500 series Cartesian gantry systems are designed for ultra-precision, high-dynamic contouring, and provide outstanding performance in precision micromachining, stencil cutting, fuel cell manufacturing, solder-ball placement, printed electronics, high-speed pick-and-place, automated assembly, vision inspection, dispensing stations, and high-accuracy inspection.
The AGS1500 is based on our industry-leading AGS15000 gantry, and maintains many of the same leading-edge characteristics but in a more compact footprint. The planar design minimizes dynamic pitch errors at the work point. The design also keeps the linear motors and linear encoders to the outside of the work area, making the gantry less susceptible to debris-induced damage.
High Speed/High Acceleration
Aerotech’s high-performance brushless linear servomotors drive the AGS1500 to speeds of 3 m/s and accelerations of 5 g. Dual linear motors and encoders are included on the lower axis for the highest level of performance and precision. The bearings are preloaded linear motion guides with wiper seals and grease fittings, and are mounted to provide optimized dynamic stiffness and load distribution. The rugged noncontact optical linear encoders offer resolutions to 1 nm when coupled with Aerotech’s controllers.
Long-Lasting Cable Management System
The cable management system (CMS) is optimized and field-proven as the industry’s most reliable design. Large bend radii and high-flex cables ensure that the AGS1500 provides millions of cycles of maintenance-free operation. In the unlikely event of a component failure, the AGS1500’s modular design ensures that part replacement is fast and easy.
All customer cabling and pneumatics can be routed through the system e-chain. Connectors are provided at the work piece and at the opposite end of the e-chain, greatly simplifying final machine integration.
Aerotech’s years of experience manufacturing precision positioning and control systems can be leveraged by acquiring a turnkey system. Typical options include Z-theta mechanisms, risers to accommodate automated parts handling equipment, brackets for flying optics components, isolation systems, and machine bases that are designed to accommodate the entire controls and electronics subsystems. In addition, Aerotech manufactures a wide range of amplifiers and advanced motion controllers that are optimized for high-performance automation applications and are a perfect complement to your Aerotech gantry.
Aerotech
www.aerotech.com/products/gantries/ags1500.html
