PI (Physik Instrumente) LP, a manufacturer of precision positioning, motion control and nanopositioning equipment, introduces the H-900KSCO hexapod, designed dynamic motion in XYZ, pitch roll, and yaw. 6-axis parallel kinematics motion is perfected by PI hexapods delivering nanopositioning precision, high speed, and stability necessary to meet today’s demanding motion control applications. More after the jump.
Applications of the H-900KSCO Hexapod abound. Applications include motion simulation (profiles compatible to ISO 20672, ISO 8728, and ISO 16328), industrial production, precision machining, automotive industry, stabilization of motion on moving vehicles and vessels.
Compact and stiff hexapod — with no moving cables
The new compact hexapod provides linear travel ranges up to 200 mm and rotation to 66° … and it is driven by brushless servo-motors and combines high load capacity (130 lbs) with fast response and high linear speeds up to 80mm/sec and angular speed of 30°/sec. The parallel kinematics design eliminates the need for moving cables and results in a very stiff and compact positioning solution, compared to conventional multi-axis designs. Watch video on versatility of PI Hexapods here.
Freely definable trajectory
The 6-axis vector motion controller provides smooth vectorised motion and a randomized, used-defined pivot point (center of rotation) that can be changed on the fly by one software command for increased versatility. Software for alignment and tracking is included, as well as for defining trajectories and sinusoidal curves with high accuracy. Additional software tools avoid collisions with surroundings in restricted workplaces. Get specifications, a full datasheet, and more information here.
Standard and custom — PI provides in-house engineered solutions with over 4 decades of experience delivering products that exceed expectations and application demands of our customers. PI can quickly modify existing product designs or provide a fully customized OEM part to fit the exact requirements of the application. Features and advantages include …
- Low-Wear, Brushless DC Motor
- Load Up to 60kg
- Travel Ranges to 200mm (linear), 66° (rotation)
- Speed: 80mm/sec (linear), 30°/sec (angular)
PI is a manufacturer of precision motion control equipment, piezo motors, air bearing stages and hexapod parallel-kinematics for semiconductor applications, photonics, bio-nano-technology and medical engineering. PI has been developing and manufacturing standard & custom precision products with piezoceramic and electromagnetic drives for 4 decades. The company has been ISO 9001 certified since 1994 and has a total staff of 850. Read the PI Blog here.
