Linear Cable Transducer from BEI Industrial Encoders
June 5, 2009 by
Filed under Linear Encoders
linear cable transducer
BEI Industrial Encoders’ new linear cable transducer provides digital position and speed feedback information in a rugged, easy-to-install package. Model LT25 cable transducer utilizes a flexible measuring cable mounted to an internal spring-loaded spool and a quadrature encoder output to precisely measure linear motion applications. The sturdy cable is made of nylon coated stainless steel for ultimate strength and has a measurement range up to 125 inches.
Easy to install, simply connect the LT25 cable to your moving equipment and secure the base to a fixed object. Hard to reach areas or worries about shaft misalignment are now not a problem. The LT25 cable transducer allows for easy reorientation of the mounting bracket or encoder connector position, giving users added adaptability to their installation. With an IP66 rating, the LT25 is a perfect solution for a variety of industrial measurement challenges including wet, dirty, or outdoor environments or applications where your measuring range travels over a harsh environment.
For more information, visit www.beiied.com/cable-transducer
