Linear Motion Slide Solution from Accuride
October 30, 2009 by
Filed under Ball Slides, Featured, Linear Guides, Linear Slides
Accuride announces the launch of Model 115, a linear motion ball bearing slide that provides captive travel within the length of the outer member.
accuride 115 linear slide
Model 115 may be side, flat, or vertically mounted. When mounted vertically, it may be used as a guide in non load-bearing applications. This product provides a low-cost solution for component guidance, support, or adjustment in a wide range of applications such as access to laptop docking stations in utility vehicles; bins for postal vehicles; reading machines for the visually impaired; traffic barriers; diagnostic equipment; and material handling in manufacturing machinery.
When mounted flat in pairs, Model 115 offers up to a 132-pound load rating; side mounted installations are up to 110 pounds per pair. A guide belt synchronizes the moving elements of the slide, ensuring smooth and consistent travel, while the moving member is fully supported on ball bearings at all times.
This product has been tested to 10,000 cycles and is available in zinc in lengths of 12″ to 28″ in 2″ increments, plus 32″, 36″, and 40″. It is RoHS compliant.
Accuride International
www.accuride.com
