Miniature Metric 8×6 Ball Screw from Nook Industries
January 15, 2010 by
Filed under Ball / Lead Screws, Linear Actuators
Cleveland, OH - Nook Industries has recently introduced its miniature metric 8×6 Ball Screw (BS) designed for light load applications that deliver fast speed and close tolerance positioning. The rare size (8mm diameter x 6mm lead) is the only precision-rolled 8×6 on the market and is designed for compact applications that require the dual ability to be fast and precise−ideal for accurate positioning requiring a rapid approach and retraction.
nook ball screw
Nook’s Precision Screw Group originally developed the 8×6 BS as part of its Miniature Metric Ball Screw Development Project primarily for medical applications. The combination of small screw and high-precision, however, is also well suited for a myriad of broad-based light load applications requiring close positioning and fast speed including; military, optics, instrumentation, sensors, etc.
Nook’s 8×6 BS is manufactured using precision rolled technology instead of grinding − which significantly lowers cost without compromising precision. Custom ball screw end machining options are also available to accommodate custom motor/bearing combinations.
Nook Industries
www.nookindustries.com/8×6
