Plastic Bearings Take High Loads
February 26, 2009 by
Filed under Linear Bearings
When both shock and impact loads are present, such as in oscillating applications, the bearing can make all the difference.  The iglide Q is a maintenance-free alternative to bronze, metal-backed and custom injection-molded bearings. Even at maximum loads of 14,500 lb/psi, it offers a low coefficient of friction compared with other iglide plain bearings.
igus iglide
As with other igus bearings, it is impervious to a range of chemicals, including organic solvents, fuels, oils and fats and, is lubrication-free, corrosion- and dirt-resistant. It operates in a temperature range of –40 to +275° F in continuous motion and can withstand short-term exposure up to 311° F. The iglide Q can be paired with an array of different shaft materials, such as stainless steel or hard-anodized aluminum. Its high-load capacity makes it a viable choice for material-handling machinery, scissor lifts, lift tables, amusement park rides and other applications.
igus
www.igus.com
