Designed for shrink-wrap case packers in high temperature heat tunnels, Rexnord recently launched its new Rexnord HTX7748 MatTop Chain. Customers around the globe with operations in the beverage & liquid and food industries will benefit from reduced oxidation, increased uptime, reliability, and more.
As the latest addition to the comprehensive line of high-strength conveying chain, the Rexnord HTX7748 MatTop Chain provides customers with:
- 42 percent open area and a smooth surface — supports heat dissipation through cooling cycles.
- Proprietary and specially engineered heat stable material — withstands heat to cooling cycles of heat tunnels, ensuring uniform cooling while also allowing for easy release of materials — resulting in less scrap, more uptime, and longer chain life.
- Engineered design for high performance and reliability — offers a heavy-duty plug and retention feature, stainless steel pins, and the Rexnord 7700 Series MatTop Chain proven base design; pins remain in place, providing a stronger chain and easy link replacement when needed.
- Technical expertise — the combination of our chain design and technical expertise helps customers choose durable conveyor systems that guarantee optimal product handling.
Rexnord
www.rexnord.com
