Nexen Group, Inc. introduces a stainless steel version of its patented precision roller pinion system (RPS). The Nexen RPS engages two teeth simultaneously to achieve superior accuracy with zero backlash at any length. The system is also extremely quiet, and 99 % efficient. Stainless steel makes the system extremely corrosion resistant, with a long life of up to 36 million meters. Nexen’s RPS provides a low maintenance, durable alternative to rack and pinion, ball screw and belt drive technology. The RPS is used for a wide range of applications including laser cutting, plasma cutting and gantry applications.
Features of the stainless steel roller RPS include:
- High speeds: 11 m/sec (36 ft/sec)
- Superior accuracy: +/- 50 µm
- Zero backlash
- Unlimited length (custom lengths and modular components available)
- Long life: up to 36 million meters
For more information visit www.nexengroup.com.
John Stokes says
Stainless steel is often used most of the kitchen appliances. Many people have no idea that sheet metal fabrication is used in so many different things! Thanks for sharing..!!
