The new GEMCO 958A embedded Linear Displacement Transducer (LDT) is a rod-style linear transducer from AMETEK Factory Automation was designed specifically with the needs of the mobile hydraulics market in mind. The rugged, rod style LDT is designed to fit entirely inside a hydraulic or clevis style cylinder and provide absolute analog feedback in the most-demanding applications and extreme operating environments.
The highly versatile 958A LDT offers absolute accuracy and reliability with high resolution and precision repeatability. The embedded LDT is totally installed inside the cylinder, which protects the transducer from outside conditions. It utilizes the latest generation of AMETEK’s field-proven magnetostrictive position-sensing technology to give absolute analog position, accurate to 0.04% of the programmable sensing distance. A variety of analog outputs are available to meet user needs.
The 958A is the ideal cylinder position sensor for applications in which there is no room to mount a standard LDT. Applications include agricultural, construction and mining equipment and commercial vehicles. Its embedded design makes the 958A resistant to contaminants and other environmental conditions.
The 958A is IP68 rated. Its rugged and durable mill-duty construction exceeds competitive offerings. Its vibration resistance is lab tested at 30Gs, and its shock resistance is lab tested to 1000Gs, greatly exceeding other competitive offerings.
The compact unit has three unique features:
- It can be powered from 8 to 30 VDC at 1.6 watts, making it easy to fit into a variety of systems.
- It features an auto-tuning capability, which allows it to sense a magnet other than the standard ring magnet and adjusts its signal strength accordingly.
- It includes a unique built-in diagnostics capability that displays the health of the unit and helps aid in troubleshooting problems if they occur.
The 958A is easy to install and set up. Units can be ordered in span lengths from 2” (50mm) to 100” (2540mm) and come standard with either integral cable assemblies, bare leads or M12 style connectors. Custom configurations are available to meet specific end user requirements.
AMETEK Factory Automation is a leader in continuous linear and rotary position sensing and level gauging. It has provided industrial automation solutions for more than 60 years. It is a recognized leader in advanced magnetostrictive positioning technology and continuous rotary and linear motion control devices.
AMETEK Factory Automation is a unit of AMETEK Sensors, Test and Calibration, which is a division of AMETEK, Inc., a leading global manufacturer of electronic instruments and electric motors with annual sales of approximately $4.0 billion. For more information, contact AMETEK Factory Automation at (800) 635-0289 or visit www.ametekfactoryautomation.com.
