Self-Lubricating Linear Bearing Pillow Blocks from Thomson
August 21, 2009 by admin
Filed under Linear Bearings
WOOD DALE, IL –Thomson introduces “Lube for Life” Self-Lubricating Linear Bearing Pillow Blocks. Lube for Life assemblies eliminate the need for expensive lubrication systems and provide continuous bearing lubrication and enhanced protection for maximum linear bearing life and true maintenance-free operation. Available for open or closed pillow block assemblies, Lube for Life can now be ordered as an option with Thomson Super Ball Bushing® Bearing and Super Smart Ball Bushing® Bearing Pillow Blocks. They come as a complete assembly for new applications, or in a retrofit kit for existing non self-lubricating pillow block assemblies.
Thomson Super Smart Ball Bushing Bearings offer more than 200 times the life of a conventional Ball Bushing Bearing. Combined with a Lube for Life assembly that promises up to three times the life of a bearing that is lubricated just once (and not subsequently) during installation, OEMs and after-market applications can realize big benefits. OEM’s will benefit from maintenance-free machines that deliver significantly longer life and increased reliability to their customers, while MRO specialists who need to replace linear bearings in existing applications will benefit from increased maintenance and replacement intervals for greater machine uptime and throughput.
Lube for Life pillow blocks work through self-lubricating cartridges pressed into each end of the pillow block housing, with the linear bearing itself initially lubricated with EP2 grease. The Lube for Life polymer is under constant pressure against the 60 Case shafting, ensuring a film of lubricant is always present between the ball bearings and the inner race. Thomson 60 Case Shafting is available for same and next day shipment, with no set-up fees on cut-to-length and special machining orders.
Thomson
www.thomsonlinear.com
I think this new type of bearing is very good because the lifetime is much more than ordinary bearings.
Thank you for your post.
