SICK STEGMANN Introduces TTK70 Motor Feedback System
November 20, 2009 by admin
Filed under Featured, Linear Encoders
DAYTON, OH – SICK STEGMANN, INC. introduces the TTK70 Motor Feedback System. The TTK70 is an absolute, non-contact linear measuring system that delivers measuring lengths up to 4,000 mm, resolution of <1 μm and system accuracy of <10 μm, at operating speeds up to 10 m/s. The result is precise and highly reliable absolute position determination for linear motors in a diverse range of applications. The TTK70 motor feedback system is rated for operation in temperatures ranging from -30…+85°C. It carries the CE mark and is RoHS compliant.
The TTK70 consists of a read head and a magnetic tape featuring a magnetic code that forms the measuring scale – 10 mm wide, and up to 4,000 mm long. The code consists of an incremental and an absolute track (twin-track tape). Absolute position values are calculated by the read head first detecting the absolute starting position during start-up of the linear motor. All further positions of the drive are determined via the incremental position on the magnetic track, i.e. sine/cosine signals. The values are transmitted via the HIPERFACE® interface to the evaluation electronics of the linear drive – a market-standard method of communication that, for the first time ever via the TTK70, is now available for linear measuring systems. The result is an interface standard for all common servo drives, that covers all applications, with only one signal type.
The robust metal housing of the read head offers IP65 protection, has two mounting holes designed for high tightening torques and, even with the plug connection, is hardly bigger than a matchbox – making it the smallest system of its kind. Inside, the TTK70 features the latest in sensor and evaluation technology. The sensor PCB, which is aligned with the measuring plane, is equipped with Hall sensors on two parallel tracks. When installed their placement coincides with the position of an incremental and an absolute track on the magnetic tape.
SICK-STEGMANN is currently the only supplier worldwide that is able to offer to drive manufacturers both rotary and linear motor feedback systems with an integrated HIPERFACE® interface, popular in applications such as erosion machines, handling systems in semiconductor production, automatic assembly and placement machines, vertical lifting systems, pick and place applications in electronic production, or the food industry.
SICK STEGMANN, INC.
www.stegmann.com
