The Wide World of Cable Carriers
May 7, 2010 by
Filed under Cable Carriers, Cables, Featured
EAST PROVIDENCE, R.I. – igus® announced the results of its worldwide cable carrier competition at this year’s Hanover show. The winners were awarded their prizes during a reception at the igus booth.
There were around 80 entries for the first Vector Awards two years ago, which was only open to European entrants. In contrast, this year more than 110 entries were submitted from all over the world: from China, India, Korea, and Singapore, to the USA, Canada and Brazil, and right across Europe.
igus Vector 10
The gold award and €5,000 prize money went to the Czech power supplier CEZ Group for the longest travel in the world ever to be accomplished with a plastic cable carrier: 2,018 feet in a lignite-fired power plant in Tušimice. A heavy-duty roller cable carrier system from igus’ 5050 RHD series is installed on the conveyer unit of the lignite excavator, which operates in extremely demanding conditions. Roller cable carriers, developed by igus for long distances, have been in use around the world for more than ten years.
CEZ Group says the robust system – which is also equipped with igus’ Chainflex® continuous-flex cables – makes a significant contribution to operational safety. System downtimes caused by cable breakage, for example, have been reduced to zero compared with before.
The jury awarded the silver Vector Award to the National Mineral Development Corp. Ltd. (NMDC) in Hyderabad, India. The state company belongs to the Ministry of Steel and carries out exploration work, among other things.
NMDC use a 61-feet long plastic cable carrier system with a rearward bending radius (RBR) on a bucket-wheel reclaimer in a steel mine. The reclaimer can rotate by +/- 180 degrees, while operating in an area that is difficult to access. The loads the cable carrier must withstand are enormous: the cables in the cable carrier alone weigh over 36 pounds per foot.
The heavy steel chain used previously in this application was damaged after just two years. According to NMDC, the igus cable-carrier system has been running reliably and with little maintenance and no downtime since its installation.
The bronze Vector Award and €1,000 prize money went to Rene Petsch, a design engineer from Deckel Maho Seebach GmbH. In this application, a traveling column milling machine underwent advanced development to make it more accurate, adaptable and economical than its predecessor. The rigid machine bed made from composite mineral and the symmetrical traveling column were to ensure improved precision.
To keep the design space compact, the Y and Z-axes of the machine use just one cable carrier: System E4.1 from igus. The E4.1 system ensures higher lateral stability, which was necessary due to the high lateral acceleration through the X-axis of 26 feet per second². The cable carrier was attached in an upright position with the run bent in at one side.
All the cable carriers applications submitted can be found on the competition website at www.vector-award.com. Video content is also available for certain entries.
The Vector competition was run in conjunction with the German Central Association for Electrical Engineering and Industry (ZVEI), the tooling laboratory (WZL) of the RWTH Aachen and TÜV Rhineland. The Vector Award is under the patronage of the Industrial Automation sector of the Hanover show.
igus
www.igus.com
