7 tools every mechanical engineer should have
As computer programs and mobile apps take over our lives, one of the great things about being a mechanical engineer is that there are still aspects of the job that allow — and sometimes require — us to do things by hand, the “old fashioned” way. And with today’s powerful engineering laptops supporting our work, we’re able to combine hands-on problem-solving with modern tools to achieve even better results.
mechanical engineering tools
Image credit: ABB Motors and Mechanical
Granted, drafting boards and T-squares have been replaced by CAD programs, complex modeling and analysis is done in a matter a minutes with FEA software, and plug-and-play configuration programs have greatly reduced the number of iterations it takes to size and select a ball screw or linear bearing. But you can’t disassemble a gearbox without a bearing puller (at least, not easily and efficiently), and you can’t measure the ID of a radial bearing without a set of calipers.
So, for those times when you get to step away from the computer and phone and get back to hands-on engineering and design, here are seven tools that will make the job easier.
NEXT PAGE →
Pages: Page 1 Page 2 Page 3 Page 4 Page 5 Page 6 Page 7 Page 8
Filed Under: Applications, Featured
  1. Momentsleutel says
    Very insightful article. Thanks for sharing this article.
  2. Conveyor Belt Vulcanizing says
    That’s a useful list of tools! Thanks for putting these together
  3. Gary says
    Yup, a good set of calipers are a definite must. Don’t go cheap on them, because it’s important that you have calipers that are accurate (and needless to say the cheap ones usually aren’t).
