Bridge Modules from Bosch
★ By Editor Leave a Comment
Charlotte, NC – Rexroth has expanded its extensive range of linear modules with the new BKK and BKR Bridge Modules designed to span long lengths without intermediate support.
The Bridge Modules consist of an extruded aluminum profile whose geometry has been optimized for extremely high torsional stiffness, reducing deflection in applications where the module is not fully supported, such as Y axes for gantry systems.
Two internal ball rail systems with four steel runner blocks are mounted inside the extrusion, at a 90-degree angle to each other, maximizing load and moment capacity.
The Bridge Modules also have an angled carriage with T-slots for flexible and secure mounting of the user’s load. Rexroth’s camoLINE connectivity allows for precise connection and alignment of additional axes. In addition, the Bridge Modules are fully enclosed with an aluminum cover and polyurethane sealing strips, protecting internal components from environmental contamination.
Rexroth’s BKR belt-driven Bridge Module is available in lengths up to 8,000 mm and provides faster speeds, while the BKK ball screw driven version is ideal for higher thrust forces and lengths up to 5,500mm. The BKK model is also available with ball screw supports to maintain high speed at longer lengths.
Standard angle brackets simplify mounting the bridge modules to Rexroth’s other linear motion systems, such as MKR, MKK, CKR, and CKK Modules. In-line motor mounts and timing belt side drives provide simple mounting of the customer’s motor.
www.boschrexroth-us.com
::Design World::
Filed Under: Stages + gantries
