The DGII Series now is available, replacing our original DG Series rotary actuator and is part of our FLEX network products. New is the addition of the High-Efficiency AR Series motor along with all the advantages of the built-in controller (stored data) type driver. High accuracy positioning can be performed while keeping the user-friendly features intact. The DG II Series offers either a built-in controller (stored data) type version or a pulse input type driver. Both come with a 3m (9.8 ft.) cable included. The DG II Series also offers new, attractive pricing making the DG II Series even more easy to use. Available in 60 mm (2.36 in.) up to 200 mm (7.87 in.) frame size with a maximum torque of 50 N·m and able to handle up to 400 N (900 lb) of permissible thrust load.
The gear-reduction mechanism employs precision gears along with a proprietary adjustment mechanism that eliminates backlash. The repetitive positioning accuracy from a single direction is ±15 sec., while lost monition in a positioning operation from two directions is 2 arc minutes. These characteristics make the DGII series the ideal choice for applications in which accurate positioning is a must.
Oriental Motor
www.orientalmotor.com
