Direct drive linear motors with integrated encoders offer high resolution
The new, SDLM-025-070-01-01 direct drive linear motor from Moticont, also known as an electric cylinder, has a built-in encoder, zero backlash, zero cogging, and provides users with high acceleration, high speed, high resolution, and long life.  This direct drive linear motor features 1.25 µm (0.000049 in.) in of resolution.  This compact direct drive linear motor is just 1.00 in. (25.4 mm) in diameter and 2.75 in (69.9 mm) long.  Inside the motor housing, the linear optical quadrature encoder is directly connected to the shaft for the greatest possible accuracy.
Moticont-SDLM-Direct-Drive-linear-motorThis direct drive linear motor has a stroke length of 0.500 in. (12.7 mm) and a continuous force rating of 22.2 oz. (5.9 N) and peak force of 67.2 oz (18.7 N).  This non-commutated direct drive servo motor features: Quiet long life plain linear bearings, an integrated internal (1.25 micron resolution) quadrature optical encoder with differential outputs, and a non-rotating shaft.  Applications include manufacturing, semiconductor handling, inspection, medical procedure tables, antenna positioning, dampers, door & valve actuators, agricultural equipment, and adjustable office furniture.
Direct coupling of the load or stage to the low inertia non-rotating shaft eliminates backlash and allows for high acceleration/deceleration.  Both ends of the motor and shaft ends are drilled and tapped for easy integration into new and existing applications.   The SDLM-025-070-01-01 Direct Drive Linear Actuator is also available as a complete plug-and-play linear motion system with a matching motion controller.
Moticont is a manufacturer of motion control products. Their product line includes voice coil motors, three phase brushless motors and positioning stages and slides.
Moticont is committed to exceeding their customers’ quality expectations and industry standards throughout the design, manufacturing, service and technical support phases. Our modern manufacturing facility, highly controlled processes, committed staff, and extensive testing complement our product design strengths. This enables us to supply our clients with specialized small orders to high volume just-in-time deliveries.
For additional information call (818) 785-1800 or visit www.moticont.com.
Filed Under: Linear actuators (all), Linear drives (all), Linear motors Tagged With: moticont
