Dual-axis pitch and roll stages precisely measure curvature and angles
The precise measurements of angles and the curvature of objects are easily determined using two new Pitch and Roll stages from OES (Optimal Engineering Systems, Inc.) The PR100-45-01 is driven by stepper motors and the PR100-45-02 is driven by brushless servo motors with quadrature incremental optical encoders.
The pitch axis (lower stage) is a high-precision goniometer stage which features preloaded cross roller guides and a high ratio worm drive for smooth motion over a range of travel of +/- 45 degrees. It has a typical accuracy of 0.05 degrees and repeatability of +/- 0.01 degrees. This axis has end-of-travel limit switches as well.
The 100-mm diameter Roll axis (upper stage) has a 180:1 gear ratio for smooth motion and has a precise pattern of threaded holes for fixtures or tooling. This axis has an accuracy of 0.05 degrees and repeatability of +/- 0.01 degrees. The Roll axis has a Home signal for initialization. Each axis features a calibrated scale to visually display the angle. The maximum speed with stepper motors is 14 degrees/sec and 45 degrees/sec with servo motors. The knobs of the stepper motors can be replaced with optional optical encoders for position verification.
stages
The resolution of the PR100-45-01 stepper motor driven dual-axis stage depends on the resolution of the step motor driver resolution or the optical encoder if a servo motor is used. A resolution of 0.001 degrees equivalent to 3.6 arc-sec can be achieved using a10 micro-steps per step stepper motor driver or an encoder with a resolution of 500 cycles per revolution.
The PR100-45-02 that features servo motors and optical quadrature encoders are used for precise closed-loop operation and greater speeds. The PR100-45-01 and -02 stages can be ordered plug-and-play with a fully a compatible multi-axis motion controller from OES.
