Electromechanical linear actuators feature embedded CAN bus support, PLC capability
July 14, 2020 By Miles Budimir Leave a Comment
Thomson Industries, Inc. has unveiled their new Electrak MD, a more compact electromechanical actuator that retains all of the intelligence built into its larger counterparts. Mobile off-highway, material handling and factory automation applications can benefit from the compact actuator with up to two kilonewtons (kN) of force, advanced onboard electronics and J1939 CAN Bus support.
“Traditionally, motion control users looking for a higher load handling system are using hydraulic actuators,” said Chad Carlberg, Product Line Manager for Industrial Actuators at Thomson. “However, these actuators are costly to maintain and use a lot of space. With our new compact Electrak MD, designers can now achieve high precision and greater flexibility while reducing costs.”
linear actuator
Onboard Electronics
The new Electrak MD also comes with onboard intelligence, which enhances the overall performance and eliminates space consumption by keeping any external equipment like encoders and switches within the actuator housing. As with its predecessor, the Electrak HD, this functionality provides a simpler method of control and communication, which minimizes operating costs and simplifies setup and installation.
In addition to the above benefits, the Electrak MD also features extensive automation and maintenance enablers such as feedback on position, J1939 CAN bus communication, low-current switching (PLC compatibility), and end-of-stroke indication output.
linear actuator
High Power Density
Many design engineers are often faced with the challenge of meeting size constraints while maintaining high force requirements. For example, with applications on a harvesting combine, past designs were cavernous enough to allow a large amount of space for hydraulic solutions to actuate the equipment with high force. Now, equipment manufacturers are tasked with reducing the overall footprint and adding functionality, resulting in an increased demand for more compact components such as the power-dense and intelligent Electrak MD.
 Electrak MD actuators are available immediately. For more information, visit: https://www.thomsonlinear.com/en/products/linear-actuators/electrak-md
  • actuator
    Tolomatic expands hydraulic-class electric actuator force range to 50,000 lbf
  • Linear motion in medical applications: Linear actuators in patient lifts,…
  • actuators
    Out with the oil, in with the screw
  • Linear guides, power transmission, actuators see unexpected applications
Filed Under: Featured, Linear actuators (all) Tagged With: thomson
