Festo Adds a Heavy Duty Unit to its Popular EGC Line
November 8, 2013 By Editor Leave a Comment
EGC model toothed belt and ball screw electric actuators from Festo deliver high speed, response, and dynamic rigidity. The new EGC-HD (heavy duty) model builds on those capabilities and adds load-bearing capacity to its specifications – twice the load bearing of the EGC actuator.
Festo-Adds-a-Heavy-Duty-Unit-to-its-Popular-EGC-Line
The EGC-HD electric actuator features recirculating ball bearing guides that help absorb lateral forces and torques. With a toothed belt or ball screw drive and two parallel guides, the EGC-HD is perfect for cantilevered systems. The toothed belt model EGC-HD-TB offers flexible motor connections on all four sides. Due to this flexible motor mounting feature, Product Manager Nuzha Yakoob, states “changes to motor configuration can be made at any time. The OEM can define a standard motor attachment with a single part number and modify that to an alternate position as needed to suit machine and customer needs.”
The EGC-HD offers a more cost-effective solution than two parallel axes. Like all EGC electric actuators, the EGC-HD offers a multi axis and modular positioning system and standardized interfaces for all drives and motor packages. Festo’s free PositioningDrives software simplifies the selection process and eliminates costly oversizing. Specially developed profiles with optimized cross section give the EGC-HD maximum rigidity and load capacity.
Optional sensing
Inductive proximity sensors can be included with these actuators. Flush mounting of up to two sensors effectively eliminates protruding edges outside of the drive’s cross section. An LED status display is visible regardless of approach direction.
Key specifications
Max. stroke 2,400 – 5,000 mm
Max. speed 1.5 – 5 m/s
Max. acceleration 15 – 50 m/s2
Repetition accuracy +0.02 – +0.08
Max. feed force 1,300 – 1,800 N
Torque Mx axis 900 Nm
Torques My/Mz 1,450 Nm
Festo
www.festo.com/us
Filed Under: Ball + lead + roller screws, Belt + chain drives for linear, Linear actuators (all), Linear drives (all) Tagged With: festo
