Gates Energy Efficient Power Transmission Drive Solutions
With energy costs on the rise, you’ve got to keep your power transmission systems performing at optimum efficiency. On average, synchronous belt drives operate at a consistent 98-99% efficiency, which is 5% more efficiently than V-belt drives. That means that converting from a V-belt drive to a synchronous drive can increase your production by 5% or lead to savings on your energy bill.
Plus, properly installed synchronous belts eliminate time spent retensioning, reduce maintenance expenses, and may save your plant thousands of dollars.
The cost-saving benefits of Gates synchronous belt drives make them ideal for a wide variety of markets, including chemical processing, ethanol refining, oil refining, and food and beverage.
Gates has your energy efficient solution.
Download an Energy Efficiency Whitepaper and the Belt Preventative Maintenance Manual here >>>
www.gates.com
Filed Under: Belt + chain drives for linear Tagged With: belt drives, Gates, transmission solutions
