The Precision Alliance’s Linear Rail Systems are designed for high temperature applications that require performance at temperatures up to 250oC. The linear rail bearing components are made from bearing grade steel with all other internal components made from high temperature metals. There are no plastic components.
The systems are available with Raydent or Thin Dense Nickel Chrome corrosion resistant plating on all bearing surfaces. The internal components are pre-lubricated with high temperature grease that won’t “drip” as the temperature rises.
The product range spans from size 15 to 65 and can directly interchange with most linear rail systems on the market.
www.tpa-us.com
Tomaž says
I am interested in buying one of these so I want to know the price of the rail and the carriages.
Thank you.
