LINAK adds integrated control to linear motion actuators
LINAK has expanded its IC actuator portfolio with integrated control for linear motion applications. The portfolio is intended to let engineers connect actuators or lifting columns directly to existing automation environments through industrial interfaces including IO-Link, PROFINET, EtherNet/IP, Modbus TCP/IP, CANopen, CAN SAE J1939, Modbus RTU and the LINAK I/O interface. This can simplify integration into existing PLC systems and reduce the need for additional hardware.
The built-in controller and functions in the actuator include movement logic such as parallel operation and run-to-position, as well as position feedback and diagnostics, depending on the interface used. This can reduce programming and integration effort and support machine development and optimization.
Application examples
At SANOVO, LINAK LA21 actuators with IO-Link are used for positioning in an egg packaging machine, with predefined recipes for changeovers.
The setup allowed SANOVO to remove mechanics, cylinders and sensors from the machine design and reduce component and labor costs by approximately EUR 2,000 per machine.
At Schur Automation, LINAK LA25 actuators with EtherNet/IP are integrated into the company’s existing automation architecture.
The LINAK IC actuator portfolio gives engineers options for actuator selection and interface choice while including integrated control, communication and functions. Each interface has been tested and validated in major PLC environments, including Siemens SIMATIC, Omron and Allen-Bradley, to support integration and communication.
The offering launched globally on October 22, 2026.
For more information, visit linak-us.com.
Filed Under: Integrated Linear Systems Tagged With: linak
About Puja Mitra
