Low-cost, high-performance alternative to rod actuators, pneumatic cylinders
August 11, 2020 By Miles Budimir Leave a Comment
Bell-Everman’s new ServoBelt RA is a high-performance, drop-in replacement actuator designed for applications that have traditionally used rod actuators, pneumatic cylinders or even linear motors. Unlike traditional rod actuators, ServoBelt RA is fully guided along the entirety of its stroke, making it more resistant to off-axis loads and more stable in on-axis moves.
With linear forces up to 200 N, speeds up to 4 m/sec, accuracy to +/- 4 μm per meter and bi-directional repeatability as low as +/- 25 μm depending on deceleration profile, ServoBelt RA performance compares favorably to linear motors that cost more.
actuator
ServoBelt RA has been built from the ground up for moving chassis installation in both horizontal and vertical Z-axis orientations. Its drive unit features standard or custom mounting hole patterns to make it easy to integrate ServoBelt RA into machines. A range of standard motor offerings enables the replacement of pneumatic cylinders simply by connecting dc power and rerouting servo-valve signals to the ServoBelt RA.
Bell-Everman ServoBelt™ RA Actuator
For more information visit www.bell-everman.com.
  • ElectroCraft expands AxialPower family of linear actuators with the APES…
  • LinX M-Series electric actuators from ANCA Motion offer direct replacement…
  • amplifier
    Linear servo brush-type amplifiers for voice-coil actuators
  • Cartesian robots
    Three important design considerations for Cartesian robots
  • linear motor
    New 20-mm linear stepper motors from Nippon Pulse
Filed Under: Featured, Linear actuators (all) Tagged With: Linear Actuators
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
Follow us on Twitter
Tweets by Linear_Motion
