Maximizing cobot ROI through seventh-axis-enabled collaboration
Robot transfer units have become increasingly important to automated settings. Now, transfer units with collision detection pair with collaborative robots for human-centric technology enabling previously unimagined levels of productivity.
Kyle Thompson • product innovation manager | Thomson Industries
Chris Diak • southeast automation manager | Motion
Most robot arms have six axes of motion, fewer than a human arm, but still plenty of range to automate complex industrial operations with speed, precision and consistency unattainable by humans. Although the cost of implementation has dropped dramatically over the years — from hundreds to tens of thousands of dollars — a robot is still a capital investment needing a solid business case. Adding a seventh axis to a traditional six-axis robot helps make that case by simplifying the transport of a single robot to multiple locations, functioning as robot transfer units or RTUs.
By design, the cobot segment within the robotics category provides collision protection to avoid human injury. When adding a seventh axis to extend robot arm capabilities, encompassing the collision protection for the seventh-axis controls strengthens the business case with a safer RTU design. With the collision protection included in the system, the RTU has now become a cobot transfer unit or CTU.
The benefits of a seventh axis
While six-axis robots are usually fixed to a single location, a seven-axis system mounts the arm on a carriage attached to an actuation element. This moves the robot along an axis as long as 10 meters, dramatically extending the range of operation as shown in Figure 1.
Figure 1. A robot transfer unit mounts a six-axis arm on a carriage that enables transfer of the arm to multiple locations, allowing one robot to do the work of various robots. Image: Thomson Industries
A movable robot opens many possibilities for cost efficiency, enabling the arm to extend its reach beyond the capabilities of a standard six-axis robot. This extra degree of freedom makes it easier for the robot to navigate around obstacles, reach into tight spaces or serve larger work areas.
Adding a seventh axis combined with motion profile recipes for each part per workstation allows the user to program one robot to act like multiple robots. An assembly application might juxtapose four milling stations in a row. When the milling targets arrive, the arm selects one and serves it to the machine. Then, instead of idling in wait for the next part, the arm would move along the seventh axis to the next workstation, repeating the operation. Most robots can free drive, which simplifies the initial training. Some seventh-axis systems also have a free-drive mode, making the whole station training easy and flexible. A robot can work with larger part trays due to its extended reach capabilities. This enables it to do more in less time, perhaps working in an envelope holding a day’s worth of millwork while refreshing the base parts overnight.
When one reviews the initial cost of $50,000 to $100,000 per robot to serve each milling station, consider that one seventh-axis robot could move between comparable operations to accomplish all the work. ROI on a single robot could justify the purchase, delivering the traditional benefits with the highest efficiency. Factoring in the possibility of labor shortages further justifies the cost because a single robot solution could accomplish work that might be reprioritized. This reprioritization could be due to a lack of trained labor or low part demand, increasing the assigned labor cost in the first place.
Human review of workcell operation
Should the milling application example incorporate a cobot, it could be useful to have a human reviewing the full process. The program can be revised for optimization and checking the milled parts for quality. However, the need to tend multiple machines in such areas would make it difficult to address all the safety demands of operating machines and humans in such proximity per the risk assessment.
Installing cages or other guard technology can degrade operational efficiency. A balance to meet the risk assessment and production requirements might let plant personnel run operations more slowly, but this might diminish throughput. Another approach is to consider collision detection monitoring on the CTU as part of the overall risk assessment, combined with guarding or safety devices appropriate for the application.
Figure 2. Thomson’s MovoTrak CTU uses collision detection paddles to sense unplanned loads from accidental human contact and stop motion. The robot arm is also sensitive to accidental human contact. Image: Thomson Industries
CTU designers can afford such a capability by deploying collision detection paddles on both sides of the carriage, where an operator might instinctively put a hand  as in Figure 2. Forces as low as 13 N — about the force used in a computer keystroke — would be enough to signal the system to stop at once. A combination of current limit and position error monitoring would enable the detection, complementing similar sensing that may already be embedded into the joints of the robot arm. In all cases, users can adjust the sensitivity of both the seventh axis and the cobot arm. They should do this based on a risk assessment that considers the motion profile, moving materials and other application aspects.
Working together with the robotic arm
In a CTU, the robots would handle the heavy lifting, precision welding and assembly tasks. At the same time, humans perform quality control, fine-tuning and complex decision-making processes, which can increase production speed and quality. Following are some applications that might benefit from human-robot collaboration.
Machine tending: In addition to the milling example mentioned earlier, machine-tending CTU applications include CNC, injection molding and presses, where one person can tend multiple machines with the same robot.
Material handling: Bin picking, packaging or palletizing could benefit by moving the robot arm to extend the human’s reach for heavy products in tight spaces.
Welding: Human control and monitoring of the arc of motion can enable longer welds.
Assembly: Human monitoring of insertion, nut driving, riveting and screw driving at multiple work locations can help maintain consistency.
Quality inspection, measurement, and testing: Shared control of quality inspection devices, such as cameras and scanners, highlights and helps fix inefficiencies.
Dispensing: With automated dispensing of dense/sticky materials such as glue or sealants, humans could enable longer beads by monitoring for consistency and regulating accordingly.
Only the beginning for robotic installations
Whether one wants to increase robot ROI in applications or design a new robot-based system, CTUs can provide quicker ROI and pay for themselves many times over.
First, they let manufacturers to address those dirty, dull, and dangerous applications (the Three Ds) more efficiently, with one cobot doing the work of many. Second, CTUs can fill gaps in staffing, letting manufacturers reach production quotas that are otherwise impossible. Finally, they improve ROI by balancing human/robot collaboration. Humans provide planning, monitoring and decision-making capabilities, and the robots enforce efficiency in the Three Ds.
Author Kyle Thompson
CTUs however are still a relatively new technology and becoming more affordable, easier to use, and essential to a highly dynamic industrial market. They will likely be key enablers in what industry watchers call the Fifth Industrial Revolution or Industry 5.0.
These terms describe human-centric and robot technology combined with AI to bring previously unimagined levels of productivity and value to automation. As engineers innovate to meet the demands of emerging markets, the greatest benefits of human-robot collaboration are yet to come.
Author Chris Diak
Kyle Thompson is the product innovation manager at Thomson Linear and has worked in linear motion for 18 years. He earned a BS in Mechanical Engineering and a B.S. in Mathematics from Virginia Tech.
Chris Diak is the southeast automation manager at Motion. He has worked in the electrical/automation field for 29 years, with the last 27 at Motion. He earned a B.S. in Electrical Engineering from Clemson University.
For more information, visit Motion.com.
Filed Under: Applications, Featured, Integrated Linear Systems Tagged With: motion, thomsonindustries
