Miniature linear-positioning stage for single and multi-axis applications
★ By Lisa Eitel 1 Comment
The L-402 compact linear stage is the newest addition to the suite of motion control solutions available from Physik Instrumente. Delivering performance and reliability at minimized cost, this affordable miniature linear positioner is well-suited for micromanipulation, test systems, and opto-mechanical alignment automation applications.
High travel accuracy — XY or XYZ combinations
With a travel range of 1/2 in.(13 mm) and velocity to 0.2 in./sec (5 mm/sec) the L-402 delivers high accuracy and smooth motion for loads up to 1-lb with minimum incremental motion and repeatability down to 0.5 microns. The closed-loop version provides encoder resolution of 0.12 microns.  Long service life and excellent guiding accuracy with minimum backlash are guaranteed by creep-free crossed roller bearings. The clever stage design allows for XY and XYZ stack configurations without the need for adapter plates.  For vacuum-applications, special versions to 10-6 hPa are available.
Which motor do you need?
The stage comes with the choice of two direct-drive motors, a DC servo motor with closed-loop encoder and two-phase stepper motor. Other encoder options for OEMs are also available.
Noncontact optical limit switches and reference point switches with direction sensing in the middle of the travel range simplify use in automation tasks.  Get specifications, datasheet, and more information at pi-usa.us/products/Compact_Positioning_Stages.
Filed Under: Stages + gantries Tagged With: physikinstrumente
  1. Harper Campbell says
    It’s interesting to know that when it comes to a piezo stage, that there is a lot of things to take into consideration for the different applications. I like how you pointed out that one thing to think about is what kind of motor one should get for the stage they are working with. This way they will be able to figure out the switches that will get them into the travel range they want.
