Multi-axis stages and tables: Manufacturer involvement and software yield turnkey motion systems
March 3, 2018 By Lisa Eitel Leave a Comment
There’s increasing demand for stages, tables, gantries, and indexing tables with simplicity or turnkey operation — largely because of industry moves toward focused expertise and abstraction. No wonder that motion-system manufacturers are now doing more integration for plant engineers and OEMs.
“As we increase our business with OEMs of various markets — including those in life science, consumer electronics, and semiconductor industries — we’ve had to adapt,” said Patrick Lehr, product manager of precision mechanics at the Parker Hannifin Corp. Electromechanical & Drives Division.
“There’s need for custom products unique to OEMs and end users and no one else. So many OEMs need singular form factors or precision specifications … and many require linear stages as small as possible without compromising on output capabilities.” It’s also the job the of stage or table manufacturer to remain cognizant of OEM cost and delivery demands when satisfying mass-produced custom projects.
Shown here is a PlanarHDX Series two-axis air-bearing stage from Aerotech Inc. All critical structural moving elements of the stage are made out of silicon-carbide ceramic. “Ceramic structures increase stiffness and reduce weight,” said Brian O’Connor, director of product and market development.  At the heart of the PlanarHDX are Aerotech’s BLM and BLMH linear motors, which employ an ironless forcer design for ultra-smooth motion. Both the step and scan axes use multiple motors driving near the center-of-mass to provide exceptional vertical/lateral straightness and minimal angular errors. The motors are thermally-isolated, and for high duty-cycle applications can be water cooled to minimize thermal errors caused by motor heating.
In fact, Lehr’s company provides services that extend beyond building custom stages for customers. Its engineering team supports designers from initial application and design discussions on the prototype through the last delivery of a mass-production order.
So Lehr suggests design engineers look for motion component and system suppliers that offer:
Design support (to help design linear stages where needed) and system integration — to build in house if requested
Diverse product offerings, with no dismissal of custom ideas without an initial investigation; special designs and materials for custom products that must perform in challenging environments
Testing — with engineering teams to run both standard and customer-requested tests before shipment
Full motion control setup (with drives, controls, and motors all in one location) and compatibility with competitors’ motors and controllers (for design flexibility)
Field support with electromechanical engineers (EMEs) available to visit during installation and service
Warranty support (with a standard warranty on all products) as well as logistic support to extend delivery and other cost savings
Other manufacturers offer multiple turnkey variations.
“Our linear-stage product line provides a complete motion solution … and our SLP linear stages for industrial users provide 1-µm resolution and forces to 970 N,” said Brian Scott, applications engineer at Nippon Pulse America, Inc.
The manufacturer also sells SCR linear stages for high-precision applications — as those in metrology, for example. The SCR stage has a resolution in the 10-nm range — and is built with cross-roller bearings for high stability.
SCR linear stages from Nippon Pulse America excel in high-precision applications such as metrology. The SCR stage has resolution in the 10-nm range and cross-roller bearings for high stability. These stages are complete mechanical systems — with integrated Linear Shaft Motor, encoder, linear guides and bearings — and come in myriad stroke lengths and sizes.
“These stages are complete mechanical systems, with integrated Linear Shaft Motors, encoders, linear guides, and bearings … and they’re stages sold in varying stroke lengths and sizes,” Scott added.
Even for Cartesian assemblies, new software tools abound to simplify integration. Case in point: A digital catalog called EasyHandling (from Bosch Rexroth) details linear-motion components that come predesigned with features for quick repeatable assembly. “Saving the design engineer from Cartesian-robot assembly efforts frees them to focus on other project-design aspects,” explained Rich Hansen, senior automation engineer at Bosch Rexroth.
Another software tool from ETEL Motors consists of an in-house sizing program that can simulate the most advanced duty cycles … and give detailed schematics on the thermal behavior of motors running it. The reason the tool isn’t available publicly is because it uses sensitive motor data to get results.
ETEL CHARON2 stacked X-Y motion stages are pre-engineered to excel in semiconductor manufacture. They’re backwards compatible with existing modules and deliver acceleration to 1 g with speeds to 1 m/sec — even with absolute positioning accuracy to below 1 µm.
“But this lets us size motors not just to a flat Nm value … but also to the duty cycle, environmental conditions, drives limitations, and more,” said Brian Zlotorzycki, product specialist at ETEL Motors. The software even predicts thermal behavior over time. “All of this makes for more thorough analysis, typically with a lot of communication with the customer — and lets specialists better understand the project as a whole while ensuring an optimized final design.”
One aspect of value-added engineering from stage and gantry suppliers in particular is the use of well-informed simulation models, Excel spreadsheets, and even proprietary software.
“Our software lets us simulate an application’s duty cycle and determine how our motors will perform in those circumstances. Ultimately the model includes heat generation, current draw, and how different ambient conditions and voltage limits affect these parameters,” explained Zlotorzycki.  This gives OEMs and plant engineers a more accurate picture of how linear-motion actuators and motors (and stages) will perform in the final machine design — and how the design is affected by minor tweaks.
V-551 Series ultra-precision positioning stages from Physik Instrumente (PI) include crossed-roller bearings with anti-creep cages assist for guide accuracy to1 µm of straightness and flatness per 100 mm. Design engineers can pick between absolute encoders (for resolution to 2 nm) or incremental encoders (for resolution to 0.2 nm) with an effective 0.5-nm minimum incremental motion at the stage platform. Ironless linear motors drive the stages to deliver high dynamics and smooth motion. That makes them suitable for designs needing extremely constant velocity … as in metrology, photonics, optics inspection, semiconductor test equipment, and interferometry.
  • Long-stroke robotic RTU applications pose new challenges for cable carriers
  • Motion trends: Linear actuators leverage modularity and connectivity
  • Linear Motion Trends: Consumer health-monitoring devices and more driving innovation
  • XY stage
    High-performance XY stage with linear servo motors from InteLiDrives
  • Gallery: Crossed-roller slide variations and uses
Filed Under: Featured, Integrated Linear Systems, Linear actuators (all), Stages + gantries
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
Follow us on Twitter
Tweets by Linear_Motion
