New integrated motor/actuator features high power density
October 8, 2019 By Miles Budimir Leave a Comment
The newest integrated motor/actuator from Curtiss-Wright’s Industrial Division, the Exlar GTX100, is the second frame size in the integrated motor/actuator series. Incorporating Curtiss-Wright’s patented inverted roller screw technology, the GTX100’s high power density and compact form factor make it a suitable replacement for hydraulic cylinders.
actuator
The GTX Series actuators offer the power, precision, and programmability of a servo system while minimizing the maintenance difficulties and mess of hydraulics. With continuous force ratings up to 15,392 N (3,460 lbf), speeds up to 953 mm/sec (37.5 in./sec), and standard stroke lengths from 150 mm (5.9 in.) to 300 mm (11.8 in.), the GTX100 can be applied across a wide range of factory automation applications.
The GTX Series features include:
  • High capacity planetary roller screws offering up to 15X the life and significantly higher shock load resistance than a comparably sized ball screw
  • IP65S (min.) environmental protection
  • Seamless integration into most leading motion control architectures
  • Removable front seal bushing greatly simplifies maintenance and re-greasing of nut assembly to maximize actuator life
  • Modular design with bolt-on mounting hardware allows effortless mounting reconfiguration or replacement in the field using commonly available tools
  • Smoother, quieter operation compared to previous generation designs
Exlar is a business unit of Curtiss-Wright’s Industrial Division. For more information visit www.exlar.com or www.curtisswright.com.
  • THK roller LM guide type HRX for myriad applications and…
  • linear actuator
    New hygienic integrated electric actuators for food/beverage processing from Tolomatic
  • actuators
    Actuators with extreme power density, reliability for aerospace applications
  • linear motion
    Linear motion systems for packaging applications from Bishop Wisecarver
  • How roller-screw and ball-screw actuators compare in high-force applications
Filed Under: Linear actuators (all) Tagged With: exlar, Linear Actuator
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
Follow us on Twitter
Tweets by Linear_Motion
