New linear rotary actuator features 35-mm stroke with 5-micron encoder
February 19, 2019 By Miles Budimir Leave a Comment
The LCR16 from SMAC Moving Coil Actuators provides precision Z-theta motion within one small actuator, which is suitable for pick, orient and place applications. A wide variety of LCR16 linear rotary actuators are available with either direct drive or gearbox equipped rotary units.
The vacuum-built-in shaft through the rotary motor is available for some models to prevent dust build-up in the unit. These z-theta actuators can easily be programmed to control force/torque, position and velocity in all axes at the same time with feedback capability. SMAC’s unique, patented “Soft-Land” function lets the unit gently land on a delicate component with a controlled force to avoid damage of both the component and the actuator.
actuator
The actuator is constructed with a direct drive brushless servo motor and is designed with linear guide built-in lubrication to offer long life cycle. It also provides absolute control over force/torque, position, acceleration and velocity.
Features include:
  • Direct drive brushless servo motor
  • Combined linear and rotary motions in a single unit
  • Fully programmable in force/torque, position and velocity
  • SMAC’s Patented ‘Soft-Land’ Technology
  • Self-lubricated linear guide
  • Low shaft run-out, 30 µm (lower run-out optional)
  • Vacuum through shaft prevents dust accumulation
  • MTBF 100 million life cycle
  • 24-Vdc operation
  • 35-mm stroke
For more information, visit www.smac-mca.com.
  • backlash and hysteresis
    What’s the difference between backlash and hysteresis in linear systems?
  • Moving coil technology: Benefits today (and innovations on horizon)
  • When did the most common linear-actuator options come about?
  • piezo motors
    What are walking piezo motors?
  • linear guide wheel
    What are some considerations for linear actuators in contaminated environments?
Filed Under: Linear actuators (all), Mini + piezo + voice coil Tagged With: Linear Actuator
