New profiled linear guideways from SCHNEEBERGER handle loads up to 150 tons
January 2, 2020 By Miles Budimir Leave a Comment
SCHNEEBERGER Inc. has expanded its MONORAIL MR profiled linear guideway series with its new MR 30 MONORAIL 30-mm rail and cross roller cartridge. The MONORAIL MR series moves especially heavy workpieces of up to 150 tons — with extreme accuracy — in milling, turning, drilling, or grinding machines.
The new MR 30, along with the entire MONORAIL MR series, delivers higher machining rates, enhanced geometrical accuracy, and improved surface quality of machined workpieces in applications ranging from industrial engine production to power plant construction to aerospace engineering to other heavy machinery construction.
The series features superior O-geometry, rather than the more-prevalent X-geometry, for extreme accuracy in positioning. Other series features include high rigidity for improved vibration control, greater dynamic and static load carrying capacity, superior rail straightness and optimized path geometries for rollers and transitions for outstanding running smoothness, and total carriage enclosure. All sizes in the series (25, 30, 35, 45, 55, 65, and 100 mm) are configurable to meet the accuracy class specific to any application — from G3 (standard) to G2 and G1, as well as the highly accurate G0.
guideways
Benefits of SCHNEEBERGER’s utilization of O-geometry in the MONORAIL MR series includes internal spacing of the load-carrying surfaces in conjunction with 90° offset of the roller tracks, uniform and high absorption of forces from all directions, and higher rigidity during workpiece movement.
Also, the series offers three different preload classes; special set processing through system grinding and paired rails supporting high accurate machines; carriage and rail types for attachment from above and from below; through-hardened carriages for long life; single-piece rail lengths of up to 6 m; no change of preload during assembly and operation; no loss of preload for constant machine execution; low drag wipers for protection against the environment and corrosion, with optional especially thin dense chrome-plating; a stainless steel cover-strip, various hole plug options for long lifespan of wipers; a variety of coatings for corrosion protection; and a wide scope of accessories and options. The MR 4S series offers an optimized lubrication system, ease of maintenance, shock resistant, and dirt repellent.
The new SCHNEEBERGER MR 30 MONORAIL 30mm rail and cross roller cartridge is immediately available.
For more information, visit www.schneeberger.com.
  • top 10 articles
    Linear Motion Tips – Top 10 articles of 2019
  • linear encoder
    Space-saving integrated guide, linear encoder from THK
  • needle roller
    What are needle roller linear bearings?
  • SCHNEEBERGER Inc. expands sales department with White, Guzman, and Trompeter
  • LinX tubular linear motor offers 10 micron resolution and peak…
Filed Under: Slides + guides (all) Tagged With: Linear Guides
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
  • Miniature controllers from FAULHABER control a range of dc motors
  • Robotic bartender powered by Arduino-compatible controller and BLDC servo motors
  • What are double- and triple-stack hybrid stepper motors ?
  • PowerSTAR right angle gearmotor features advanced precision hypoid gearing
  • What are different ways to express a gear ratio?
Follow us on Twitter
Tweets by Linear_Motion
