Southco, Inc., a global leader in engineered access solutions has added to its line of electronic actuators with a sealed version that simplifies the upgrade from mechanical to electronic actuation. Capable of accommodating higher mechanical loads, the AC-EM 10 electronic actuator facilitates the electronic actuation of Southco’s R4-10 rotary latch series and other latching mechanisms.
Southco’s versatile AC-EM 10 electronic actuator delivers high efficiency, accommodating heavier loads with minimal current draw. When connected to an electronic access control device, the AC-EM 10 electronic actuator can be used to remotely actuate a mechanical latch to open or unlock a door or panel.
With its small profile design and efficient gear motor operation, the AC-EM 10 electronic actuator is ideal for concealed applications where physical space constraints are a challenge. An economical solution for remotely actuating rotary locks and latches, the AC-EM 10 is tested to IP55 for water and dust protection and can be easily retrofitted using a standard cable connection for manual override.
According to Steve Spatig, General Manager of Electronic Access Solutions at Southco, “The AC-EM 10 electronic actuator delivers an efficient and cost-effective solution for electronically actuating rotary latches. The actuator is easy to install and requires minimal power to accommodate typical latching loads.”
