New voice coil stages feature 1-micron positioning resolution
July 3, 2019 By Miles Budimir Leave a Comment
The compact open aperture HCDS-051-032-013-01-B1-30 and the HCDS-051-032-013-01-B1-01 Voice Coil Stages from Moticont have a footprint of just 2.000 in. (50.8 mm) wide by 5.000 in. (127.0 mm) long and feature positioning resolutions of 30 microns and just 1 micron respectively. These precision stages allow the user to select the level of precision needed for an application.
The 1 micron resolution HCDS-051-032-013-01-B1-01 Voice Coil Stage features cross roller linear bearings whereas the 30 micron HCDS-051-032-013-01-B1-30 Voice Coil Stage uses linear ball bearings. Each of these stages has a 0.97 in. (24.6 mm) range of motion with 6.3 lb (28.2 N) of continuous force and 20.0 lb (89.9 N) peak force. These brushless, clean, quiet, efficient, low inertia, high acceleration, zero cogging and high speed voice coil driven stages have a built-in home switch for accurate initialization. As the coil is fixed and the magnetic assembly moves, there are no moving electrical components to fail. Designed for closed-loop servo operation an integral quadrature optical encoder with differential outputs is included.
stages
The stages’ 1.509 in. (38.3 mm) x 2.000 in. (50.8 mm) tables are equipped with four 8-32UNC-28 mounting holes. Pre-drilled and counter-bored mounting holes in the base of the stages and a plug -and-play wired connector allows for easy integration into new or existing applications. These black anodized voice coil stages with a 0.500 in. (12.7 mm) clear aperture are suitable for: Laser drilling and machining, optical focusing, testing, laser steering, mirror positioning, scanning, oscillation, switching, as well as precision applications in industrial, medical, metrology, and research fields.
The HCDS-051-032-013-01-B1-01 and HCDS-051-032-013-01-B1-30 Voice Coil Stages are also available in XY or XYZ configurations, and can also be ordered as a complete plug-and-play system with a controller.
  • Physik Instrumente XY stage provides high speed and 10-nm resolution
  • stages
    Miniature linear translation stages in X, XY, and XYZ configurations
  • linear stage
    Linear motor stage offers long travel, nanometer resolution
  • Compact voice-coil motors from Moticont with 1.0-in. diameters for myriad…
  • voice coil actuators
    When are voice coil actuators the best linear motion option?
Filed Under: Integrated Linear Systems, Stages + gantries Tagged With: moticont, stages
  • New servo and motion bundles simplify machine integration
  • Kit encoders now included in product finder portal from POSITAL
  • Mitsubishi Electric Automation launches new online request-for-quote tool
  • ABB launches new app for rapid, remote tech support
  • ABB opens global innovation and training campus for machine automation at B&R in Austria
