Next-gen electric actuators for high forces
August 28, 2016 By Danielle Collins Leave a Comment
Curtiss-Wright Sensors & Controls Division has announced the release of its next-generation Exlar® brand FTX Series actuators. These high-force electric rod style actuators now offer higher performance and ease of maintenance than previously available.
electric actuatorsThe FTX Series actuators leverage more than a decade of experience successfully replacing hydraulics in high-force, high-duty cycle applications in harsh environments. Based on planetary roller screw technology, the FTX Series offers high robustness in a compact form factor, making them an ideal alternative to hydraulic cylinders. With continuous force rating to 178 kN (40,000 lbf), speed to 875 mm/sec (34 in/sec) and stroke lengths from 150 mm (6 inches) to 900 mm (3 feet), the FTX Series can be applied across a wide range of linear motion applications.
The FTX215, a next-generation version of the current FT80 model, features the following key enhancements over the existing FT Series designs:
  • High capacity planetary roller screw offers up to 15X the life and significantly higher shock load resistance than a comparably sized ball screw
  • IP65 (min.) environmental protection
  • Idler pulley design greatly simplifies motor installation and belt tensioning / maintenance
  • Grease zerk fitting and removable front seal bushing greatly simplify maintenance and re-greasing of nut assembly to maximize actuator life
  • Modular design with bolt-on mounting hardware allows mounting style reconfiguration in the field using commonly available tools
Filed Under: Ball + leadscrew driven, Industry news, Linear actuators (all) Tagged With: curtiss-wright, exlar
