PHD releases two new linear slides
★ By Mike Santora Leave a Comment
PHD-Optimax-linear-actuatorBuilt on the foundation of long-life products for industrial automation, PHD Optimax actuators are designed to meet machine builders’ performance requirements. These economical, efficient, and reliable actuators provide an alternative choice to PHD’s standard “built-to-order” product line, delivering even more cost-effective solutions to meet industrial application needs.
In a continuing effort to expand the Optimax product line, PHD is pleased to release two new drop-in replacement linear slides designed for the OEM market. These actuators are versatile and economical for use in the machine builders’ market.
Optimax Series OSW Dual Bore Pneumatic Slide Tables are robust linear actuators designed for high power in compact spaces.
Benefits include:
• Drop-in metric mounting matches global standard
• Roller bearing guide provides precise motion and high load capacity
• 6 bore sizes available in incremental travel lengths
• Dual piston bores provide high power
Optimax Series OSP Compact Pneumatic Thruster Slides are robust linear actuators designed for high performance applications where slide length is a concern.
Benefits include:
• 8 bore sizes available in incremental travel lengths up to 100 mm
• Magnets standard for switch sensing capability
• Standard shock pads reduce end of travel impact
PHD
www.phdinc.com/optimax
Filed Under: Linear actuators (all) Tagged With: phdinc
