EAST PROVIDENCE, R.I. – Igus® Inc. offers iglide R, an economical, maintenance-free alternative to bronze bearings. Iglide R incurs little to no low wear even at high speeds and also is oil-free and resistant to dirt, dust and UV rays. These qualities make iglide R an ideal choice for agricultural and outdoor applications, specifically commercial mowers and golf course equipment, which benefit from its contamination-free properties.
Like all iglide bearings, iglide R is comprised of high-performance plastics that are lightweight and lubrication-free. Unlike bronze bushings, which require regular maintenance and lubrication, engineers can install iglide R and forget it. It will not only outlive its bronze counterparts, but also will reduce costs and never corrode.
Iglide R operates within a permissible temperature range of –58 degrees Fahrenheit to +230 degrees Fahrenheit. It can be used in linear, oscillating and rotating applications and is available in both sleeve and flange styles with inner diameters ranging from 3/16 of an inch to 2 inches. Iglide R can be used in a wide range of environments, including those where water or chemicals are present, due to its low moisture absorption and resistance to alcohol, greases, oils and fuels.
When choosing any iglide plastic bearing from igus, users will enjoy:
Contact a design technician today for free samples of iglide R bearings.
