Plastic Modular Belt Conveyors
Line of Modular Plastic Belt (MPB) Conveyors combine increased durability and reduced maintenance in a quiet, compact package.  The conveyors are available with 0.5- or 1-in. pitch belting in widths from 2 to 24 in. and lengths to 29 ft, and they are ideal for a range of industrial, packaging, labeling, automation and processing systems.
Belt and sprocket life are increased through a 200-degree positive-contact drive sprocket belt engagement mechanism that eliminates the return link contraction. Maintenance costs are lowered through reduced component wear, self-aligning sealed-for-life bearings, and a compact quick-change direct drive.  A tip-up tail section permits interior access without belt separation.  Center tracking eliminates belt lateral end-drift and potential belt run-off, as well as virtually eliminating belt and guide edge-wear.
The quiet, compact drive occupies approximately one-half the space of conventional systems, and the reduced height beyond the drive end allows the conveyors to fit into shallow height applications. The drive is devoid of belts, chain, sprockets, couplings and their related maintenance, and it can be totally replaced and ready to run in under five minutes.  Also, the drive does not require disengagement when removing, or installing the belt.
Conveyors are available with an entry nose bar for small part transfer and all units carry a two-year,  unlimited hour warranty.
Conveyor Technologies Ltd.
www.conveyortechltd.com
Filed Under: Applications, Belt + chain drives for linear Tagged With: Belt and sprocket life, Conveyors, durability
