Rollon redesigns TV actuators for industrial linear motion
Rollon has introduced redesigned ball-screw-driven TV actuators with changes to moment-load capacity, internal protection and operating flexibility.
Available in sizes 65, 80 and 110, the TV actuators provide precise and repeatable linear motion for industrial applications.
The redesigned actuators use two linear guide blocks positioned at the maximum practical distance from each other, with the ball screw nut between them. This arrangement increases the support span for handling moment loads.
A polyurethane sealing belt protects the ball screw drive and linear guide system from contaminants. Micro-bearings inside the carriage guide the belt and help limit resistance as it moves through the carriage.
The TV actuators are available with different ball screw leads to support various speed and load requirements. For longer strokes, an optional internal ball screw support helps reduce shaft deflection and allows higher operating speeds.
The actuators are designed for industrial automation, packaging and robotics applications requiring precise and repeatable linear motion.
Ball screw technology for precise linear motion
The TV actuator range combines a rigid construction with a ball screw drive and linear guidance system. A linear rail with two preloaded recirculating ball bearing blocks and a square cross section provides guidance, with positioning repeatability of up to 5 μm.
Dedicated lubrication channels for the linear rail and ball screw support maintenance of the actuator during operation.
The redesigned TV series provides machine designers with options for meeting different precision, load and speed requirements in automation systems.
For more information, visit rollon.com.
Filed Under: Ball + leadscrew driven Tagged With: rollon
About Puja Mitra
