SCHNEEBERGER announces SFERAX Type H.L. linear ball bearing
March 8, 2021 By Kelsey Zebrowski Leave a Comment
SCHNEEBERGER Inc. has announced the availability of the new SFERAX Type H.L. linear ball bearing — featuring high-quality engineering at a competitive value point.
Developed to support a linear bearing under high loads and high radial torques, the new SFERAX Type H.L. linear ball bearing is ideal for uses ranging from peripheral devices to assembly machinery to injection molds, as well vertical applications such as vertical presses — and more.
The SFERAX Type H.L. features a 100 Chromium-6 steel housing, hardened to 63 HRC, ground (lapped for quality grade A), a brass ball tray, and precision 100 Chromium-6 steel balls. The SFERAX Type H.L. is approved for wide temperature use, -30° to +200°C (without seals). Its three external grooves make mounting easy.
The SFERAX Type H.L. linear ball bearing is available in a variety of precision grades, including B.A./Medium Improved, A/Good, XA, and Z.A. It is offered for use with a wide variety of seals and shaft tolerances, and fits.
The new SFERAX HL linear ball bearing is immediately available. For more product information, visit this deep link www.sferax.ch. Or call SCHNEEBERGER, the exclusive representative for SFERAX in the U.S., at 1-800-854-6333.
  • How do miniature profiled rail guides compare to their full-size…
  • guideways
    New profiled linear guideways from SCHNEEBERGER handle loads up to…
  • Zygo Names SCHNEEBERGER as a 2019 outstanding supplier in quality…
  • needle roller
    What are needle roller linear bearings?
  • SCHNEEBERGER Inc. expands sales department with White, Guzman, and Trompeter
Filed Under: Linear bearings Tagged With: Schneeberger
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
  • Miniature controllers from FAULHABER control a range of dc motors
  • Robotic bartender powered by Arduino-compatible controller and BLDC servo motors
  • What are double- and triple-stack hybrid stepper motors ?
  • PowerSTAR right angle gearmotor features advanced precision hypoid gearing
  • What are different ways to express a gear ratio?
Follow us on Twitter
Tweets by Linear_Motion
