Greenville, DE – Servo2Go has just added a new high performance linear stage series to its broad range of positioning systems.
Manufactured by Zaber Technologies Inc., the T-LSM series devices are computer-controlled motorized linear stages with high thrust and speed capabilities and a very compact size. They are stand-alone units requiring only a standard 15V power supply. A potentiometer knob at the end of the unit permits smooth manual control; turn it fully to get maximum speed. These slides connect to the RS-232 port of any computer and can be daisy-chained with up to 254 units per chain. They can also be chained with any other T-Series products. Convenient 6-pin mini din cables on the unit allow for direct interconnection between units in close proximity. For longer distances, a standard cable extension can be used.
Series Overview:
* 25 to 200 mm travel (custom options available)
* Max. centered load 100N
* Built-in controller
* Compact design featuring high speed, high thrust and high accuracy
* Mounts in an XYZ configuration without any additional hardware
* Several units can be daisy-chained to a single serial port
More information on the T-LSM series linear stages can be viewed at – http://www.servo2go.com/product.php?ID=105215
Servo2go
www.servo2go.com
