THK’s GL-N actuators are compact linear actuators intended for space-limited automation, positioning, and inspection applications. The series integrates guidance with the actuator to support controlled linear motion.
The GL-N-BS model uses an aluminum base and caged-ball LM guides and adds a QZ lubricator for the ball screw, which is intended to extend lubrication intervals and reduce routine maintenance.
The GL-N-B model uses an aluminum base and caged-ball LM guides for the guide system.
For more information, visit tech.thk.com.
