In two weeks, IMTS visitors will be able to see THK’s ballscrew-spline BNS-V at booth #134514. Featuring an exceptionally compact and lightweight structure, the low-inertia BNS-V enables quick starts and stops during high-speed operation.
The BNS-V is a stroke-rotary unit with ball screw grooves and a ball spline groove that cross one another on a single shaft. The nuts of the ball screw and the ball spline have dedicated support bearings directly embedded on the circumference of the nuts. Some advantages of the new ballscrew-spline BNS-V include a highly rigid shaft support, an angular-contact structure for highly accurate positioning and smooth motion with low noise.
The BNS-V is a downsized version of THK’s ballscrew-spline BNS-A — widely used in industry. The BNS-V features a compact ø72 outer diameter, a low weight of 1.00kg and a low inertia of 2.00kg•cm2 … contrasted with the BNS-A ø86 outer diameter, weight of 1.67 kg, and inertia of 4.32kg•cm2.
THK manufactures the widest range of linear motion products, including LM guides, ball screws, mechanical actuators and ball splines and more. All THK products have been designed and manufactured to meet the strictest requirements. THK’s experienced Global Engineering Team can provide customized linear motion solutions from their standard linear motion products as well as from mechatronics products for the most demanding applications.
For more information, visit www.thk.com.
