    • Cam + wheel guides
Three-axis gimbal mount from OES features high resolution and stability
July 3, 2018 By Miles Budimir Leave a Comment
The new AU300-AER three-axis gimbal mount from OES (Optimal Engineering Systems, Inc.) features full 360˚ rotation of each axis. This three-axis gimbal mount handles loads to 10 kg (22.5 lb) and has a clearance of 300 x 300 mm, (11.8 in. x 11.8 in.) around the roll axis stage. The azimuth stage rotary table is mounted on a large 360 x 360 x 13 mm (14.173 x 14.173 in. x 0.512 in.) plate with handles and has predrilled accessible mounting holes for easy integration into new or existing applications, and for increased stability. The AU300-AER three-axis gimbal mount is ideal for mounting cameras, optics, lasers and instrumentation for scanning, tracking, positioning, pointing, and other applications.
gimbal mount
The three axes (azimuth, elevation, and roll) are driven by bi-directional stepper motors capable of microstepping, and have knobs for manual adjustments. The roll axis table measures 100 mm (3.937 in.) in diameter. The knobs may be replaced with optical encoders for position verification and closed loop positioning. Each axis features low backlash worm gear drives and precision “V” groove and cross roller bearings for high resolution of 3.6 arc seconds, and repeatability and positional accuracy to 36 arc seconds. Travel speed of each axis is 8˚ per second. Electrical connections are made using three 9-pin DB-9 connectors.
The AU300-AER Motorized Three-axis gimbal mount can be ordered as a complete plug-and-play system with a multi-axis controller, joy stick, track ball, or keypad, and with a 30-mm thru hole in the roll stage.
  • voice coil actuator
    High-torque rotary voice coil actuators from H2W
  • Differential windlass drives: How new designs work for linear motion
  • Linear motion designs see wider adoption of linear direct drives
  • Dover Motion DOF-5 stage — a low-cost alternative to piezo…
  • linear stages family
    New high-performance linear stages family with ball screw and linear…
Filed Under: Integrated Linear Systems, Stages + gantries
Leave a Reply Cancel reply
Your email address will not be published. Required fields are marked *
  • Saving energy and service cost with electric linear systems
RSS Most Recent Articles
  • Variable frequency drive with integrated functions for roll-to-roll applications
  • New four-quadrant PWM regenerative drive from American Control Electronics
  • High-torque synchronous belt for industrial applications
  • Integrated servo motor offers design benefits for mobile robotic applications
  • What is pitch in the context of conveyors?
Follow us on Twitter
Tweets by Linear_Motion
Follow us on Twitter@linear_motion
Add us on FacebookDesign World Network
Add us on LinkedInLinkedIn
Add us on YouTubeYouTube
Add us on InstagramInstagram
Copyright © 2019 · WTWH Media LLC and its licensors. All rights reserved.
