Tolomatic electric actuators with longer strokes (to replace fluid-power cylinders)
April 10, 2018 By Lisa Eitel Leave a Comment
Tolomatic high force electric rod-style actuators now feature stroke lengths to 1.5 m (60 in.) for more flexibility for converting motion control applications with hydraulic or pneumatic cylinders to electric linear motion. Designed for high duty-cycle performance in demanding applications, the RSX, RSA and ERD electric rod-style product families use planetary roller screws for longer service life in a compact package compared to electric actuators using ball screw technology.
Tolomatic’s highest-force actuator, the RSX, is expanded to 1.5 m stroke length (from 600 mm). The RSA and ERD are expanded to 1.5 m and 1.2 m, respectively, from 450 mm.
The RSX uses a tie-rod design, provides forces up to 133.5 kN (30,000 lbf) and is suitable for hydraulic replacement applications. The RSA HT is available in four sizes, forces up to 58 kN (13,039 lbf) and is the most flexible product line for fluid power replacement. The ERD stainless steel, hygienic electric actuator rated, rated IP60k for applications in the food and beverage market, is available with forces up to 35 kN (7868 lbf). Tolomatic’s IMA servo linear actuator and ServoWeld spot-welding servo actuator platforms are also available with roller screw configurations at various thrust ratings and stroke lengths.
“Compared to hydraulic or pneumatic cylinders, electric actuators provide better motion control, superior flexibility, better efficiency, no contamination risk, and few maintenance concerns,” said Aaron Dietrich, director of marketing, Tolomatic.
“With these expanded roller screw options, Tolomatic is one of the few companies worldwide with this level of capability to replace fluid power cylinders. With the added benefit of 10 to 20 times the life of an equivalent ball screw actuator, roller screw actuators bring much more value to customers looking for long life actuator setups.”
Tolomatic’s roller screw actuator families are available with unique features to aid conversion of fluid power cylinders and maximize life, including easy re-lubrication and IP (ingress protection ratings) from IP65 to IP69k.
  • Tolomatic integrated servo motor and drive (with PROFINET) automates simple…
  • planetary roller screw
    What are planetary roller screws?
  • high speed linear actuators
    High-speed linear actuators: What qualifies them as high speed?
  • roller screw actuator
    Roller screw actuators: Design and applications
  • servo
    Tolomatic food-grade servo actuator for food and beverage processing
Filed Under: Applications, Ball + leadscrew driven, Featured, Linear actuators (all) Tagged With: tolomatic
