Value-added piezo-element assembly speeds up OEM integration and saves cost
Fast response, high bandwidth and force, and virtually unlimited resolution make piezoelectric transducers invaluable to modern high tech applications including flow measurement, distance gauging, bio-medical dispensing and aerosol generation, as well as metrology, semiconductor testing, and aerospace technology. PI, a leader in piezo ceramic and motion control solutions, offers value added piezo components by adhering flexible printed circuits for easy application integration. More after the jump.
value-added-piezo-element-assembly-speeds-up-oem-integration
Summary of the piezo-electric effect
Piezo materials – mostly special ceramic formulations – generate an electric charge when a mechanical force is applied. This behavior is called the direct piezo effect. Conversely, when an electric field is applied to a piezo transducer, it will change its shape (inverse piezo effect). The response is very fast, allowing oscillations in the ultrasound range up to millions of Hertz. Learn more about piezo transducer applications here.
No soldering needed with these piezo components
Traditional integration of piezo components requires soldering by experienced personnel to electrically connect the transducers. PI’s new flexible printed circuits provide the necessary electrical contact, securely and easily, without soldering. Automated attachment is now easily possible providing greater versatility and saving cost and time-to-market.
Customizable piezo elements with encapsulating and more
PI’s Ceramic Division specializes in OEM customization of piezo elements including encapsulating or mounting to an existing customer component. Learn more about piezo-transducer custom assemblies here …
… and more about piezo-actuator products here.
Made from ferroelectric soft or hard piezo materials and available as spheres, disks, rods, cylinders, plates, blocks, rings, and tubes, PI can custom-design components to match the requirements of the individual application.
PI provides in-house engineered solutions with more than four decades of experience delivering products that exceed expectations and application demands of our customers.  PI can quickly modify existing product designs or provide a fully customized OEM part to fit the exact requirements of the application.
Filed Under: Linear actuators (all), Mini + piezo + voice coil Tagged With: physikinstrumente
