What factors contribute to air bearing stiffness?
According to the American Society of Mechanical Engineers (ASME), stiffness is:
The capacity of a mechanical system to sustain external loads without excessive changes of its geometry (deformations).
When we think of stiffness in traditional bearings with rolling elements, we’re typically considering the deflection of the carriage when a load is applied. For air bearings, which use a thin film of pressurized air to support the load, stiffness represents the bearing’s ability to maintain a consistent air gap — in other words, to resist changes in the air gap due to compression of the air caused by an applied load.
Air bearing stiffness is the derivative of the bearing’s load capacity versus the air gap thickness (lift).
Image credit: New Way Air Bearings
Because air is a compressible medium, any change in loading will change the thickness of an air film between two surfaces — for air bearings, this means that an increase in load will cause a decrease in the air gap, due to the compression of air. Thicker air gaps are more compressible than thinner air gaps, so air bearings that are designed for high stiffness typically operate with extremely small air gaps, on the order of a few microns.
As the load on an air bearing increases (within the bearing’s rated load capacity), stiffness also increases.
Image credit: Roger Cortesi, MIT
In addition to the size of the gap, another factor that affects air bearing stiffness is compensation, which is the method by which airflow into the air gap is controlled. Compensation works to create a restriction of airflow thru the orifice and into the gap, before the restriction of the gap itself. This restriction provides a restoring force when a load is applied or increased, allowing the bearing to resist compression of the air gap due to the increased load. In other words, the restricted airflow through the orifice provides “reserve” pressure that can maintain the air gap when external forces attempt to compress it.
nanopositioning
With no mechanical elements to generate friction or heat, air bearings – and air bearing stages, like the one shown here – are ideal for applications that require extremely high precision and stiffness.
Image credit: Aerotech Inc.
Like rolling element linear guides, air bearings can also be designed with preload to increase stiffness. There are several methods for creating preload on an air bearing: adding mass (weight), applying a vacuum to the air bearing, installing magnets on the moving and stationary parts, and combining two opposing bearings to create preload between them. Regardless of the preloading method, the result is the same: as a load is added to the bearing, the air gap compresses and the pressure increases, and so does the stiffness of the air film.
While it’s difficult to compare the stiffness of an air bearing with a rolling element bearing (due to functional and size differences), it’s important to note that the air film supporting the load in an air bearing provides a continuous area of support. In contrast, rolling element bearings — whether they use balls or rollers – rely on multiple, very small areas of contact to support the load. And the stiffness of a rolling contact bearing depends on several non-linear factors that are difficult to model or predict, whereas air bearings have very predictable, linear stiffness characteristics.
Filed Under: Applications, FAQs + basics, Featured, Stages + gantries
