Wye Cylinders endorses igus polymer bearings
Wye Cylinder Engineering recommends the use of iglidur polymer bearings from igus together with its products.
Offering improved reliability and maintenance-free operation, the bearings are typically used in a pivot point, which provides the end of a hydraulic cylinder shaft with an articulated coupling. Wye Cylinder Engineering has provided most of its customers with cylinders fitted with iglidur bearings.
iglidur-polymer-bearings1
Igus iglidur products are resistant to the effects of dirt and vibration, which is particularly important because the cylinders are used in demanding working conditions such as: a range of agricultural machinery, mini excavators, commercial and material handling applications to mention just a few where high levels of contamination are unavoidable.
igus
www.igus.com
www.wye-cylinder.co.uk
Filed Under: Linear bearings Tagged With: igus, Wye Cylinders
