Applimotion’s LARC Series linear arc motors are now being used in 360 degree applications. These motors are ideal for rotating large diameter mechanics that do not require fast acceleration or the high torque you would otherwise get from large traditional motor. If you have a set of rotating mechanics that you need to rotate at fast or slow speeds, or position, the LARC motor gives you a low cost, low profile alternative.
These motors operate from a traditional three phase motor controllers in sinusoidal control mode or six state control mode. They can also be used as generators. Motors can be wound for voltages covering 24-400 volts. They produce sinusoidal torque curves and have zero cogging. Their low profile and high pole count also make them ideal for torque production or power generation.
Typical applications include scanning, imaging, and inspection. Application segments include medical diagnostic devices, pick and place machinery, and metrology equipment.
