High Precision Rotary Stage from Steinmeyer
Steinmeyer announced an addition to its line of precision rotary stages. The standard DT130-DC stage is a worm gear driven unit with a rotary encoder and features positional accuracy of +/- 0.07 degrees, repeatability of +/- 0.007 degrees, a max speed of 15 rpm and a load capacity of 50 Newton. Drive mechanism is a DC servo-motor. This stage is ideal for applications such as:
DT130 Rotary Stage
  • Laser Machining
  • Precision Wafer Inspection
  • Photonics
  • Fiber Optics
  • Cell diagnostics
The DT130-DC can also be equipped with a direct reading encoder attached to the rotating stage for higher positioning accuracy. Stage body is manufactured from a low distortion aluminum alloy (black anodized) and includes a high stiffness bearing set. This rotary stage is designed to easily mate with our MT130 linear stage.
Steinmeyer
www.steinmeyer.com
Filed Under: Industry news Tagged With: steinmeyer
