New simulation software from PI aids hexapod selection
Powerful new simulation software from PI (Physik Instrumente) determines if a hexapod is suitable for a specific positioning task, in terms of workspace, load, center of mass, and operating orientation. The tool helps in making the correct choice for the application at hand.
A hexapod, also known as a Stewart Platform, offers motion in 6 degrees of freedom (XYZ, pitch, roll, yaw). Different models are available to handle loads up to 2,000 kg. The parallel kinematic design provides a tremendous advantage over conventional multi-axis positioners constructed from a stack of single axis stages.
The flexible concept of hexapods can easily solve complex motion and alignment problems in fields including optics, photonics, precision automation, automotive, and medical engineering.
hexapod
With a large basis of standard precision motion products and proven methodologies, PI is in the position to quickly modify existing designs or provide a fully customized OEM solution to fit the exact requirements of your application from the whole motion range from finger-tip sized nano-positioners to large scale stages with long travel ranges, through a plethora of different drives and guiding systems.
Download the Hexapod Configuration Software here.
Filed Under: Integrated Linear Systems, Software, Stages + gantries Tagged With: physikinstrumente
