Tolomatic doubles the speed of high-force IMA linear servo actuator
The compact, heavy-duty Tolomatic IMA integrated linear servo actuator is now available with additional ball screw offerings that more than double the speed range, from 24 inches per second (610 mm/sec) to 58 inches per second (1,473 mm/sec). The IMA is CE/UL approved.
Designed for long life in high duty cycles, the IMA delivers high force in press fitting systems; accurate positioning and quick response in valve and process control; compact, lightweight spot welding; and smooth velocity fluid dispensing. When designed with food-grade white epoxy coating and stainless steel components (available as catalog orders), the IMA provides corrosion resistance, ingress protection and bacterial growth protection for food and beverage industry applications.
Tolomatic-Actuator
The IMA integrates a servo motor into a ball or roller screw-driven actuator to provide efficient high force in a compact, lightweight design. The IMA55 high-force servo linear actuator with roller screw option boosts its thrust capability to 6,875 pounds force (30,470 N). The patented long-life design eliminates the need for couplers, adapters, belts and gears and allows for easy re-lubrication without disassembly.
Available in four sizes, the IMA line of integrated-motor rod actuators features stroke lengths from three to 18 inches (76.2 to 457.2 mm).
Tolomatic
www.tolomatic.com
Filed Under: Ball + lead + roller screws, Linear actuators (all) Tagged With: tolomatic
