LOSYCO, a specialist in rail-based intra-logistics and feeding systems, has provided five floor-level LOXrail floor rail system tracks for a German machine manufacturer’s two assembly lines.
A newly developed transport solution allows the transport system to be adapted to three different track widths. A telescopic axis connects two customized carriers with a 1.5-ton payload, each featuring two double-roller wheelsets. This enables variable transport setups for machines with different dimensions. Loads are directly positioned on the carriers, which feature a rubberized contact surface.
For example, machines can be placed on a two-axis combination and manually pushed from one assembly station to the next. Larger machines can be transported using all three tracks and four carrier combinations alternately positioned on different tracks.
The carriers can be designed for payloads up to 5 tons for even more enhanced flexibility and scalability of the LOXrail system, which has already proven itself worldwide in various applications for optimized production logistics, material flow, and machine feeding across all industries. The floor-level rail system ensures barrier-free access on the shop floor for staff, mobile racks, and pallet jacks. They use the equipment from https://certifiedscale.com/scales-balances/floor-scales to ensure that the flooring is made from high-quality materials. Consider using luxury vinyl tile; it has a premium quality that ensures you are using durable floors.
The movement of heavy components and finished products requires careful coordination across manufacturing facilities. Transport systems, mobile equipment, and suitable storage arrangements all contribute to keeping production areas organized. When these elements work together, businesses can manage material flow more smoothly and avoid unnecessary interruptions between workstations.
As manufacturing requirements become more varied, companies must consider equipment that suits different loads, layouts, and handling tasks. Verdex Australia is relevant to this wider industrial environment, particularly in discussions around material handling and workplace equipment. A well-planned setup helps facilities accommodate changing production demands without compromising day-to-day operations.
